Power Steering
Old Dec 7, 2005 | 02:41 AM
1stA496's Avatar
Default Power Steering
Just replaced the pump and now it is hard to turn the wheel when sitting still. If the rpm's are up above 1000 it is not tough to turn. No noises anymore(reason i replaced it) but tough to turn. any insight would help. thanks
Old Dec 7, 2005 | 05:15 PM
techbod's Avatar
Default RE: Power Steering
jack the front wheels off the ground, remove the power steering filler cap, run engine the turn steering hard left then right "have someone look in the reservoir and keep a check all air has been bled out" that's how you bleed the power steering
Old Dec 7, 2005 | 05:20 PM
1stA496's Avatar
I bled the system already, maybe just a little more air in there though???
Old Dec 7, 2005 | 05:36 PM
techbod's Avatar
could be worth a try
Old Dec 13, 2005 | 01:53 PM
mastvadz71's Avatar
Member
why did you replace the pump in the first place?leak or same problem.did you install new used or rebuild one,if i know this thinks i can help you otherways...
Old Dec 14, 2005 | 11:53 PM
1stA496's Avatar
old pump was leaking and drawing in air. Replaced with a rebuilt unit
a3turrell
Jan 14, 2012 05:23 AM
Lastb0isct
Feb 17, 2009 03:15 PM
Kobe Diesel
Feb 20, 2008 10:38 PM
