PowerLocks
Old Oct 4, 2005 | 04:02 PM
Bbarn's Avatar
Default PowerLocks
<-----Noob
I found this forum when searching about a problem I have. Im glad to have found it, seems like a great forum.
I own a Black 97 A4 quattro 2.8
I was driving down the highway and when I hit my blinker I heard a sound from behind the center of my dash that sounded liked wires shorting out. I didnt realize until a few days later that my doorlocks no longer work with my key or with my alarm. My alarm still works but the door wont lock, as well as the trunk. I imagine that these issues are related and I am not sure of what the problem may be. I can hear the motor for the powerlocks running from the rear passenger side of the car when I try to lock/unlock the doors, so its obviously not the fuse. Has anyone had this problem?
Old Oct 5, 2005 | 12:31 AM
flyboy's Avatar
Default RE: PowerLocks
you may have just run across a coinsidental vacume leak at the same time this other thing happend. does the blinker still work and as for the door locks, they can VAG-com it an find if the system is working properly and welcome to the forume.
Old Oct 5, 2005 | 01:21 AM
Bbarn's Avatar
yeah my blinkers still work. its just the locks that are messed up. I havent seen any problems due to the noise from the blinker situation.
I would definitly like to get to the bottom of this problem without going to a mechanic. I enjoy working on the car myself and I am always wanting to learn more. I guess it just goes against my morals to take it to the dealer.
Thanks
Old Oct 5, 2005 | 05:02 AM
flyboy's Avatar
I feel you there. If you can locate someone with a VAG or possibly if you really want to have a handle on your ride get one yourself, than you should be able to find if it is indeed a leak or another problem. Also Give this a few days to sit and collect somemore resposes.
Old Oct 5, 2005 | 11:37 AM
Bbarn's Avatar
Thanks for your help and hopefully I'll see some more responses.
Old Oct 7, 2005 | 12:18 AM
Bbarn's Avatar
OK now the car is really f*cked. I go to turn the car off today and when i turn the key to the OFF position, it kicks forward. So i have to turn the igition and slide the key out, then it jumps forwards and i have to jimmie the key around till i can get the ignition back far enough to slide the key in to turn it back on. The alarm doesnt even work either. So when i get the key out of the ignition i guess the car doesnt realize its off (so the radio doesnt turn off and i get a beeping sound like the lights are on) so all i can do is manually turn off the radio and lock the doors. And then to boot the headlights wont turn on. All this happened in the order I wrote it, over like a 15min span. WTF is wrong?
Oh and when I got out of the car with it running it sounded like crap, the engine was making a rattling sound, the stearing seemed to be tight too.
The car was riding AWESOME before all this happened a day ago. Something had to go wrong which resulted in a domino effect. Any ideas?
Thanks in advance for any help.[:@]
Old Oct 7, 2005 | 06:09 AM
russianari's Avatar
i dont see a problem , you admit to owning an audi.
Old Oct 9, 2005 | 07:07 PM
Bbarn's Avatar
I had the ignition switch replaced and the ignition and alarm both work!
alex05
May 14, 2008 10:48 PM
