question about maf sensor?!?!
Old May 27, 2009 | 03:32 PM
b5audi1.8t's Avatar
Default question about maf sensor?!?!
I was just wondering befor i have to buy a new maf sensor how to tell for sure if its the problem are it is shot. i get really bad gas milage and the car when its cold and i first start it up will have trouble finding idle but then after that it idles fine. when i get on the gas the cluster says normally 8mpg and it will have good pick up then let off then good pick up again. anyone else have this problem b4. the check engien lights is on it says mass air flow signal too low. the car is 2000 a4 1.8t all help is Appreciated!!
Old May 27, 2009 | 07:40 PM
CRAZYHAWK's Avatar
If you have p0102, it is probably bad.
Old May 28, 2009 | 01:16 AM
bigern45's Avatar
yeah, usually when a code sets for a component malfunction, it is bad.. you need to check for vacuum leaks, that could cause a maf code because its job is to determine the amount of air coming into the car, so if you have a leak it could possibly be judged as a improper reading of air coming in through the air filter...
Old May 28, 2009 | 07:11 AM
b5audi1.8t's Avatar
im going to have to check the code number and for vac leaks thanks for the info
HJ Matroni
Mar 9, 2013 11:07 AM
congsitu
Jan 23, 2012 02:27 PM
mattavant
Aug 26, 2011 08:19 AM
interlude
Aug 1, 2010 10:18 AM
AdamBlackB5
Mar 20, 2008 12:10 PM
