rear diff fill plug strip and drain plug stuck help 96 a4 2.8
help. i have a 96a4 2.8 question is i strip the fill plug to my rear diff fluidl and the
drain plug won't even moved, what should i do. i changed every other fluid in this car this is my last maintances item. my car has 163,000 so far ever it run great. i put money in fixing it up, so i just want to take good care of it. if you look at the tech post it should the two both. need help please |
RE: rear diff fill plug strip and drain plug stuck help 96 a4 2.8
Use plenty of pb blaster and give it plenty of time. Youll need some sort of remval tool to get the stripped plug out.
you need that remove tool shown couple of times on Truks @ Power Block @ Spike
you will have to drill a small hole and stick that in and turn gently. also firts try the fill plug, then the drain plug. but before, get new ones also. |
