rear diff fill plug strip and drain plug stuck help 96 a4 2.8
Old May 20, 2006 | 10:32 PM
werkwitdis's Avatar
Default rear diff fill plug strip and drain plug stuck help 96 a4 2.8
help. i have a 96a4 2.8 question is i strip the fill plug to my rear diff fluidl and the
drain plug won't even moved, what should i do. i changed every other fluid in this car
this is my last maintances item. my car has 163,000 so far ever it run great. i put money in fixing it up, so i just want to take good care of it. if you look at the tech post it should the two both. need help please
Old Jun 3, 2006 | 02:35 AM
dankhound's Avatar
Default RE: rear diff fill plug strip and drain plug stuck help 96 a4 2.8
Use plenty of pb blaster and give it plenty of time. Youll need some sort of remval tool to get the stripped plug out.
Old Jun 4, 2006 | 02:07 AM
kakarot's Avatar
you need that remove tool shown couple of times on Truks @ Power Block @ Spike
you will have to drill a small hole and stick that in and turn gently.
also firts try the fill plug, then the drain plug.
but before, get new ones also.
a2thy
Feb 4, 2010 12:15 AM
hottubbrad
Dec 16, 2009 11:24 PM
cmacelo121
Dec 11, 2009 08:38 PM
jchaffee1
Oct 27, 2008 09:42 PM
seabassx
Nov 14, 2006 02:14 AM
