share with you the 12.12 VCDS China VAG 12.12 software install guide
Old Jun 11, 2015 | 12:22 AM
AutoAnna's Avatar
Default share with you the 12.12 VCDS China VAG 12.12 software install guide
Vag com 12.12 can fully works for all for VW, for Audi, for Seat and for Skoda models through the current model year(from 1994 to October 2013), including models using a direct CAN connection for diagnostics.CnAutotool share with you the 12.12 VCDS China VAG 12.12 software install guide
12.12 VCDS China Vag 12.12 software install guide
1. Drivers path: C:Ross-TechVCDS
2. Computer time into 2013.10.1 (each software prompts to change the system time expired are to this time), turn off all network connections.
3. Please never connect it to Internet and update the software.(only use this CD-ROM softwares)
4. To avoid loss and damage of software data, please dont pull up and plug USB and OBD port during the use(open the software and communications within car).
5. Please make sure all the antivirus programs are closed before using, it is very important.
Another fantastic aspect which makes the Autel MaxiDAS DS708 one step over the old, as well as a few of the new, is its new memory abilities. The brand new DS708 remember fondly the past automobiles it's already scanned to find out or no new problems have happened because the last diagnostic.The brand new diagnostic scans tool striking the marketplace is only going to be affordable, simpler to make use of, safer, and much more accurate than in the past. Creating the brand new Autel DS708 might be your shop's greatest mistakes.
The new generation platform stands out in a variety of tools by providing incredibly high performance with intuitive operation. Right for the first time, workshops and technicians could find an OE-level diagnostic solution designed for the aftermarket. The DS708 is the key to gain customer confidence and boost your bottom-line. So Can you accept to be left behind?
I hope you are not the type who like to procrastinate while shopping. Or you are one person with the habit of piecing through information to arrive at a better deal. The search for a best OBD2 scan may have led you here. I can assure you, you are in the right place. This scan machine, the Autel Maxidas DS708 Automotive Diagnostic and Analysis System have what it takes to solve your motor vehicle emission problem.
ameenqureshi
Sep 20, 2013 11:24 AM
Artrip
Mar 28, 2008 09:12 PM
khj677turbo
Jan 6, 2007 10:02 PM
camelpilot
Jan 6, 2007 03:00 AM
