Simultaneous error codes p0411 & p0171
Old May 10, 2011 | 12:11 PM
WhitefeatherTexas's Avatar
Default Simultaneous error codes p0411 & p0171
Hi guys.
I drive a 2002 Audi A4 1.8t Quattro 5 speed. 94k
I recently had a check engine light flick on due to the error codes P0171 (Bank one too lean) and P0411 (Secondary air pump insufficient air flow detected). I checked all the hoses and found a small hose connected to the manifold that had deteriorated and also a check valve that was corroded. I replaced the two parts and disconnected the battery to reset the check engine light. The light stayed off for about 160 miles but returned as I was driving to get a state inspection done .
Does anyone know why these two codes would pop up simultaneously?
Old May 13, 2011 | 01:09 PM
ianxponent's Avatar
I recently had the P0411 code on my 2.8 30V and tried to inspect the small vacuum lines and decide which needed to be replaced. I found a couple but after I replaced them, wound up with the P0411 code again plus two other codes! I ended up replacing all the small vacuum hoses and that appears to have fixed the problem. Moral of the story is: it's really hard to tell for sure if one of those small vacuum hoses is bad or not so it's better and not that difficult to just replace them all.
Old May 14, 2011 | 11:09 PM
scottrod's Avatar
I had the exact same problem bro, had to do a boost leak check which I found a good tutorial on a4mode.com, turned out to just be a cracked hose, fixed both error codes after replacing
Old May 17, 2011 | 10:23 PM
Default Thanks
I've
Replaced a few pipes but I haven't been able to get the codes cleared yet. I think Auto Zone can do otnd
scottrod
Jan 22, 2011 02:46 AM
HuskyRips
Aug 13, 2010 06:01 PM
HuskyRips
Aug 9, 2010 10:25 AM
Nick_UltraSport
Jan 27, 2009 10:51 PM
Rodneylynn1977
Jul 17, 2008 11:00 PM
