Sluggish acceleration
Old Feb 2, 2007 | 03:30 PM
darkminotaur's Avatar
Default Sluggish acceleration
I have a '01 2.7 t auto with 92000 miles. The car has the following symptoms: Gas cap does not release pressure when opened, the check engine light turns on sporadically, and performance is a tad sluggish...
especially in top gear between 2 and 3k rpm's. Any suggestions? I replaced spark plugs and cleaned my k&n air filter three months ago... but have not replaced fuel filter.. is there any?
Thanks beforehand,
Denis
Old Feb 2, 2007 | 03:33 PM
2k S4's Avatar
Default RE: Sluggish acceleration
Ok, the light turns on & you never had the codes read?
My bet is, the codes will tell you what is failing.
The evap system might have a problem, can't help with out codes. Basically the car has a valve that vents the gas tank, yours doesn't appear to be working. The CEL should tell you where to look.
Old Feb 2, 2007 | 10:21 PM
CRAZYHAWK's Avatar
If you intend to keep the car for a while get a VAG-COM or a code reader.
Old Feb 3, 2007 | 04:00 AM
SAudi's Avatar
Im gonna take a crack at it and say its your egr valve throwing a code, mine did the same thing and ran kinda lsuggish till i cleared it
Old Feb 10, 2007 | 10:05 PM
a6xlr8s's Avatar
When you changed your k&n the oil probably coated your mass air flow sensor wire. That will cause cel and sluggish performance because the MAF controls the fuel mixture and the oil coating will mix the fuel rich. Stand behind the parked running car and smell the exhaust. You will know if it is wrong by the smell. Good luck!
Skythe
Oct 14, 2011 05:04 PM
Ryanb83
Aug 22, 2011 07:16 AM
Brians01A6
Apr 3, 2010 04:58 PM
audiA487
Oct 6, 2009 08:09 PM
MG_NUT
Jul 4, 2008 02:04 PM
