Spark Plug Help?!
Old Oct 25, 2008 | 04:41 PM
Rmonster's Avatar
Default Spark Plug Help?!
I recently purchased an 01 audi a4 Quattro (Turbo) 1.8L, and i want to change the spark plugs.
I originally wanted to try using the Bosch Platinum +4 but as i googled for more info, ive seen several warnings on using them on cars with turbos.
My question is... what spark plugs should i use? platinum vs copper? multiple electrodes or simply 1? NGK vs Bosch? If i should use regular old electrodes which ones exactly should i purchase?
I would really appreciate any help/advice that i can get. Thnx
Old Oct 26, 2008 | 01:18 AM
rplets15's Avatar
i would go with just a good old bosch platinum it will last longer then copper and with having more electodes doesnt really gaurentee a better or bigger spark
Old Oct 26, 2008 | 09:23 AM
CRAZYHAWK's Avatar
PFR6Q NGK Platinum are OEM.
Old Oct 26, 2008 | 04:45 PM
Das Für B5 S4's Avatar
Default Plugs
Denso IK22 if you have a chip, otherewise I believe the IK20.
Pros:
Smaller electrodes provide a condensed spark and have only one place for the spark to spark to. Iridium offers less resistance than platinum.
Old Oct 26, 2008 | 11:20 PM
Darkprodo's Avatar
Listen to crazyhawk... the most effective spark plug is the one Audi recommends.
i'll take an engineers word over a bosch salesman... lol @ platnium +4 (what does that even mean)
Old Oct 27, 2008 | 05:26 PM
Rmonster's Avatar
Thanx for all the advice. i googled PFR6Q NGK, are they really 12 bucks a plug?! (i kno stupid question but im a complete noob here). dont get me wrong, ill get them if i gta but if there are any other cheaper alternatives that can still help maintain my car's longevity let me kno.
and last question... Do i have to gap them? Thnx again
Old Oct 28, 2008 | 10:38 AM
CRAZYHAWK's Avatar
You can use their copper plug.
Old Oct 28, 2008 | 01:15 PM
I agree with crazy hawk. From what i learned when I did research for my plugs i found that the coppers were always recomended at some point. If the car is stock they are the perfect plug. If you can afford it at all I would def suggest the NGK's or the Denso's. With and Audi/VW you will usually have to spend a little more to get the results you want.
Jake
Old Oct 29, 2008 | 02:25 AM
bigern45's Avatar
coppers are always a good choice with turbo engines..
Old Nov 8, 2008 | 01:42 PM
Rmonster's Avatar
thanks for all the advice, i actually made up my mind n purchased the ngk bkr6e... one problem... theyre not copper, i opened the box expecting to c copper plugs, n somehow ended up with silver (platinum?) bkr6e plugs.... can i use this? whats the difference between the ones i have with the copper 1s that everyones familiar with
