Stereo not working
My stereo is not working with no power and im having trouble finding the fuse box to check the fuse in my 03 audi A4. Does anyone have any suggestions?
RE: Stereo not working
fuse box is left of the dash board... between the door... if you open the door there is a flat panel that needs to be removed. it behind there.
if the fuse is good. still pull it out and put it back in. sometimes this resets the radio and allows it to work again. its an indicator of a bad unit and needs to be replaced |
ok thanks for you help man
I checked the fuse for the stereo by taking it out and putting it back in, but still doesnt work. That means the radio is but and needs to be replaced?
Theres also a fuse on the back of the radio itself.. you need a special tool to remove the radio but i've seen that fuse blown before.. sometimes unplugging the radio from the harness and plugging it back in fixes the problem.. you would have to see the dealer for that tho.
Do you guys think this stereo will work on my 03' audi a4. Here is the link for the stereo:
Boss Audio BV7950 CD Players,MP3 CD Player,DVD Players,In-dash Video [IMG]local://upfiles/50900/716D6A9FFF5E46CD9C8FDCF6A06442A0.jpg[/IMG] [IMG]local://upfiles/50900/2329F58554DB4D66BD58005088ECBF9B.jpg[/IMG] |
I had the same problem, it was a 99 though (using my VAG and then when i tried to turn the radio on it wouldnt work) fuse wasnt blown, however i just pulled the fuse out and let it sit for like 2 hrs (you could try overnight too idk) and it fired right up.
