timing belt/ car dosent start???
Old Jan 30, 2005 | 02:38 AM
idice's Avatar
Default timing belt/ car dosent start???
hey my car start overhiting. i took it to Audi diler. they told me the termostat and the waterpump are not working. so i changed them but since i took the cramshaft(timing belt?) out my car just keeps kranking but not starting. i checked everything and i found out that my sparkplugs dont get a spark??? any ideea what it can be???? thanx any info it will really help me. thanx a lot. p.s i have been told that there is a crank sensor. is there one??? thanx a lot.
Old Feb 21, 2005 | 12:26 AM
gidrew's Avatar
Default RE: timing belt/ car dosent start???
Well you shouldnt have taken the camshaft out to replace the timing belt or do a water pump. If you do take the cam out, or the t-belt off, most likely your timing is off. with your timing off, your distributor is off, and throw a spark at the wrong time. Also, if your timing if off, you could have pretty much destroyed the head if you keep cranking it over. You may have damaged the pistons, bent valves, so on. Double check to see if the timing is all set and your distributor and plug wires are all in the right places.
MyFreeAudi
Aug 9, 2013 09:56 AM
mtnbiker13
Mar 8, 2009 06:32 PM
ericmorin
Aug 15, 2006 12:23 AM
idice
Feb 19, 2005 12:09 PM
idice
Jan 30, 2005 02:36 AM
