Vag-com
Vag-com
Hello from Canada
I'm fairly new to Audis; I got one a couple months ago as my DD. It's a 97 2.8 A4 Quattro, 5spd.
Recently the CEL came on during a trip, I have also been having some idle issues (after driving a while in bad traffic, engine would sometimes die coming to or at a stop, with a lower than usual idle speed).
I understand that I need a vag-com tool to check what the code is. I've seen two types, one with a cable with software that you'd use with a laptop (similar to dataloging I'd assume), and the obd2 scanner type.
So I have two questions.
Which should I get? This is just going to be DD, I just want something that I can scan and reset codes/oil light/etc (since I'll be doing the servicing myself).
Also, where's the best/cheapest place for me to get it?
Thanks you!
Thanks you!
So I was able to get one of the local forum members to help me with a scan, and it's throwing this code
17517 - Oxygen (Lambda) Sensor; B2 S2: Voltage too Low / Air Leak
It's also accompanied by stalling issues when it's warm/hot, and it's getting progressively worse. At first it was intermittent when it was hot, how it's all the time even a minute into driving.
Stalling when going into neutral is a symptom of a vacuum leak right?
The B2S2 o2 sensor was replaced in '06 due to the same code... so i feel like that shouldn't be the problem (but then again it could be a poorer quality aftermarket unit).
Any thoughts?
Any thoughts?
