Valve Cover Gasket
Hi,
I have a 1999 Audi A4 2.6 Quattro and recently I was told that I need to have a Valve Cover Gasket replaced and that I have to go to the dealership for this. Is this something that is expensive to fix? Thanks for all of your help! |
RE: Valve Cover Gasket
Im assuming yours a European member, but it shouldnt be too hard to fix if you do it yourself, dealers will probably overcharge, for the vavlve cover gasket all you should have to do is remove the retaining bolts on the valve cover, remove, put in new gasket with alittle bit of RTV sealnt and put it back on. really not a hard job or expensive if you do it yourself.
If you are changing one vcg than you should do both. Most dealers will charge for both, do the leaking one, then if the other one goes they will fix it under "warrenty" from the original job. Hopefully you have a dealer you can trust and won't pull that stuff. Also, the proper job for changing the valve cover gasket includes changing the inner gaskets (one per side) also.
Yes, do both. While not hard, it takes some time. Expect about 3-6 hrs. The first time is the hardest & will take the most time.
Might as well replace the spark plugs while you are in there. |
But is this an expensive procedure? Is there anything else I should have them look at as well?
Thank you! |
ORIGINAL: wisheson_stars But is this an expensive procedure? Is there anything else I should have them look at as well? Thank you! |
that's the diy price. dealers will charge you about $800-$900 to do this. very easy to do yourself and there are some great writeups around to give you step by step instructions.
Thanks for all of your help! I really appreciate it. I took my car into the dealer and they told me that it is actually the Cam Shaft somethings and I should also get the Timing Belt changed. They said it was going to be about $1500. So, I called my regular place and they said they could do it all for about $500. Sometimes I wish I was a mechanic and knew how to do all of these things myself! Thanks again for all of your help.
Originally Posted by 2k S4
(Post 478054)
5hrs labor, $80 for the gaskets
Originally Posted by modset
(Post 479377)
