Valve Cover Gasket
Valve Cover Gasket
Hi,
I have a 1999 Audi A4 2.6 Quattro and recently I was told that I need to have a Valve Cover Gasket replaced and that I have to go to the dealership for this. Is this something that is expensive to fix?
Thanks for all of your help!
RE: Valve Cover Gasket
Im assuming yours a European member, but it shouldnt be too hard to fix if you do it yourself, dealers will probably overcharge, for the vavlve cover gasket all you should have to do is remove the retaining bolts on the valve cover, remove, put in new gasket with alittle bit of RTV sealnt and put it back on. really not a hard job or expensive if you do it yourself.
If you are changing one vcg than you should do both. Most dealers will charge for both, do the leaking one, then if the other one goes they will fix it under "warrenty" from the original job. Hopefully you have a dealer you can trust and won't pull that stuff. Also, the proper job for changing the valve cover gasket includes changing the inner gaskets (one per side) also.
Yes, do both. While not hard, it takes some time. Expect about 3-6 hrs. The first time is the hardest & will take the most time.
Might as well replace the spark plugs while you are in there.
Thanks for all of your help! I really appreciate it. I took my car into the dealer and they told me that it is actually the Cam Shaft somethings and I should also get the Timing Belt changed. They said it was going to be about $1500. So, I called my regular place and they said they could do it all for about $500. Sometimes I wish I was a mechanic and knew how to do all of these things myself! Thanks again for all of your help.
FIVE HOURS labor for the valve cover gasket? You have to be joking. This should be an hour at most. Also, the valve cover gaskets are $26 for aftermarket and $35 for OEM at ECStuning.com
Which is absolutely a bullshit rate. Seriously, I paid $50 for four gaskets (inner and outer for each head), and spent about an hour doing the work. It's easy to do, although "easy" may depend on how much wrench time you have in your past. Still, I know a few people with very little mechanical history who've done this job without trouble and in less than two hours. Don't hesitate to try it.
robert.jones
12-10-2008 08:01 AM
robert.jones
12-10-2008 07:56 AM
