is this what bad cam chain tensioner sounds like?
Old Oct 13, 2007 | 01:06 PM
ggggrant's Avatar
Default is this what bad cam chain tensioner sounds like?
I have this horribly annoying vibration/rattling/clacking that has been coming from my car at around 2.2-2.4 k rpm only. No noise at idle. Sounds like from inside or behind passenger side dash. I can hear it loudest on the bumpy dirt road i live on when going about 12mph in 1st gear. It goes with engine speed, not car speed but is by far loudest when on a bumpy road.
I hope this is not what cam chain tensioner sounds like? it almost sounds like it's behind the glove box/footwell... in that area
If i push in the clutch, it stops as the rpms drop back down, but resumes if i rev it back into this rpm range even with clutch disengaged only if the car is still moving (especially on bumpy roads). I cannot produce the sound by revving it parked, or if i can it's so faint I can't notice it.
car is 99 1.8t quattro 5spd
thanks for looking!
Old Oct 13, 2007 | 02:18 PM
auditech79's Avatar
Default RE: is this what bad cam chain tensioner sounds like?
No if the noise goes away when depressing the clutch its probably something going out on the clutch.
Most likely a throw out bearing, your gonna need a new clutch soon.
Old Oct 13, 2007 | 02:24 PM
ggggrant's Avatar
even though it does it with clutch pedal depressedwhen i just rev it while moving?
Old Oct 13, 2007 | 03:04 PM
auditech79's Avatar
Could be, post a sound clip of it, a bad cam chain tensioner sounds like a diesel engine.
Old Oct 13, 2007 | 03:22 PM
ggggrant's Avatar
Thanks, I will do that. It's definately not a diesling noise... which is probably good because I hear the tensioner can be a costly repair.
Old Oct 13, 2007 | 03:38 PM
Knock's Avatar
that is your muffler
go to any mechanic.. tell them my muffler needs some tightening up
i wouldnt pay more than 20$
(had same problem and fixed it myself yesterday)
stahnky
Oct 25, 2010 05:23 PM
itsbttrtopless29
Aug 2, 2009 11:05 PM
Mlaubach
Aug 20, 2008 01:38 PM
JohnnyBravoA4
Jul 20, 2006 05:20 PM
jcwolfe
Mar 28, 2006 03:56 PM
