Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Aftermarket CAT
Old Jan 4, 2012 | 03:24 PM
walda356's Avatar
Default Aftermarket CAT
Hi all, new to forum.
Does anyone have personal experience with replacing OEM cats with aftermarket?
I have 2001 A6 4.2 with 130K miles. P0420 (cat converter, bank2) keeps popping up. I reset the code, it's OK for 2 weeks and then it comes back again. I have not check the voltage (cold) on the rear O2 sensor, but I suspect that the CAT is going bad and I am looking for less expensive route that buying a cat from dealer. Is anyone running an aftermarket cats that have lasted? My tech will put in anything I select but he will not warranty the aftermarket (if it needs to replaced within months timeframe), and will charge me labor.
I appreciate your feedback.
Thanks
walda356
Old Jan 13, 2012 | 10:20 AM
rodhotter's Avatar
most brandname cats will work, if in calif. be sure its legal, some hiflo cats will set a check code and need a program or anti fouler setup, be search as there are many, APR, techtonics tuning etc, usually the cat is welded to downpipe so buying a separate cat can up labor costs to weld in over an easy bolt in with the pipe, stainless as your original prolly is will last MUCH longer, type 304 stainless is best. i replaced 3 rear oxygen sensors in my 01 jetta 199xxx miles, they are cheaper than the cat!!!
oukno
Jan 5, 2015 12:33 AM
vw754
Feb 4, 2009 10:35 AM
joeyharp
Feb 16, 2008 02:33 PM
cmk87
Sep 4, 2006 06:46 PM
harley
Jan 10, 2003 09:51 PM
