Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
bov
Old Apr 7, 2007 | 07:16 PM
youngA4's Avatar
Default RE: bov
BOV is no good for audi.
Old May 13, 2007 | 12:54 PM
im.a.real.vegetarian's Avatar
Default RE: bov
i got a forge diverter valve and a evo intake and i get a pretty loud pssht sound deffinatly not like the gay ricer sounds but its a good sound more cleaner if that makes sence hahaha
Old May 14, 2007 | 10:55 AM
Mac_17's Avatar
Default RE: bov
Well that doesn't make much sense because a DV recycles the air in the the system. So if you here a swoosh then you have an air leak, torn throttle boot or that new intake is loose.
Old May 21, 2007 | 02:27 PM
Joeski's Avatar
Default RE: bov
In short, stay away from the BOV. Go with a Bailey, Forge, Hyperboost, etc....you'll be fine!
OOOO
Old Jun 28, 2007 | 01:53 PM
c346123's Avatar
Default RE: bov
bov's don't work good on audis, the only time that they would is if you have your chip programed for it but i don't reccomend it because if you did get one after every time you let off the gas it would release the excess pressure into the atmosphere but then your car would run either lean or rich after every time it released the pressure which in turn would through the exhaust manifold have carbon buildup on your catyalitic converter. and after a while you would need to get a new one and a couple of other problems would arise so overall don't get a bov its just not worth all the problems that would comes with it.But i'm pretty sure that your car already has a diverter/bypass valve on it, it should be located under the carbelow the passenger headlight and you shouldn't replace thatone unless its chipped.
Old Jun 28, 2007 | 06:12 PM
project13's Avatar
Default RE: bov
SEARCH........ young Jedi..... use the force luke....
