Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
If i take off the cat...
Old Feb 21, 2005 | 04:27 PM
Hornyturbo's Avatar
Default If i take off the cat...
Will the check engine light come on?
Old Feb 22, 2005 | 11:58 AM
audihere's Avatar
Banned
Default RE: If i take off the cat...
pretty sure it will and youll lose a noticable lowend power from what ive read of other peoples experience. although you will gain top end. so it depends on what you use your car for. as for the cel light its most likely to happen unless i believe if u shim up your rear o2 sensor so its out of the way of the direct flow of the exhaust gas u should be all right.
Old Mar 5, 2005 | 02:45 AM
audiboy1618's Avatar
No your undoubtably get one, belive me. Just stick a black insert behind the cel. You wont even know its there, then just scan once a week.
Old Mar 6, 2005 | 04:37 PM
audihere's Avatar
Banned
well i thought if u shimmed up the o2 sensor out of the way of the exhaust flow that it wouldnt set the cel light. also if u really understand electronics you can put like a resistor or some kinda electrical gismo into the path of the o2 that will trick the ecu into thinkin it is getting normal readings from the o2. this is called a o2 spoof. alot of other car companies make them when deleting a cat.
Old Mar 19, 2005 | 10:32 PM
TomRitt's Avatar
I've heard this as well and will post next week when I try it
Old Mar 25, 2005 | 11:10 PM
macky2114's Avatar
my friend shimmed his o2 on a is300 and it didn't set the cel so i don't c y it would do if for audi then again germans man thought of everything lol
Old Apr 30, 2005 | 02:21 PM
trailboss's Avatar
when i installed mine i got a cel. I installed the spark plug non fowlers and it went away. Check out this post, test pipe info
Old May 2, 2005 | 08:28 PM
soupie69uk's Avatar
I have a supersprint de-cat pipe and my car cel light has not come on.
However my A4 doesnt have a lamda sensor after the cat just before.
Cheers
