intake box question
I own a 99 a4 5spd quattro and I am quit sad I have no turbo sound or blow off sound but I was told by a friend all I have to do is replace box with a cone filter is this true if so what do u do with the maf and all those vac lines oh and this question is not related bit how do I vr some more bottom end HP out of this car
Originally Posted by a499noob
(Post 1339135)
Do I have to get a whole intake or can I get just a cone like nu friend said
No the whole intake box will be required, in changing that it opens up air flow that is restricted, the stock air box limits the amount of air that can come in also keeping noise down. I've been looking at some for my car ' 2002 a4 quattro 1.8T' intakes for mine are between 250-350 dollars depending on manufacturer.
Ok so just so I got this strait I can't just pull off box and put a cone on correct? I have to buy a new turbo inlet and cone can I leave stock d vaulve on and acheave the same effect or does that have to be up graded to
You sure don't need to have a box. You could pick up a cone filter but you'd need to do a little fabrication. You'd need to integrate the mass air flow sensor and housing and a hose for the secondary air injection. It would be way cheaper than an intake for your car. Or do the Swiss cheese airbox mod. Cheapest route
Originally Posted by redline380
(Post 1339166)
Hey I didn't advise it. Not like id do it but the guy wants sound so I deliver
Never said I was going cheap I just wanted to know if the cone thing was tru I'm not rigging anything ill be placing my order for a turbo inlet aka intake pretty soon thanks for u guys help
To be quite honest here, i have heard about this swiss cheese cut out in the intake box which i've been told produces the most hp gain and it's cheap. I've yet to believe this until i see actual numbers that prove that this mod works. But who wants a bunch of holes in their intake box under the hood, not me!
