Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
A6 Centre console cup holder- removal
Old Dec 5, 2013 | 08:49 PM
hughsutherland27's Avatar
Default A6 Centre console cup holder- removal
I read many threads but non were specific on this-The cupholder in the centre console - which holds the cup, can be removed without taking off the console- It is held in by friction and two small plastic clips in the front the holder- however the fit into the retaining section is tight and may require lubricant and or a thin blade loosening the centre portion on all sides- there are also two grooves which hold it in place and line it up for a straight up pull out- If you press back (outwards) the two clips and can get a firm grip on the unit it will pull directly up and slide out- nothing holds it except the two clips and friction- I found this out by getting a replacement unit from the wreckers by removing a damaged console and lifting out the whole unit- holder and its retaining case- then by tapping on the bottom of the unit while the upper edges were supported if just neatly popped out so I did not have to remove my own good console- just keep trying and have faith- it will come out and the replacement will just slide in
polepar
Feb 18, 2015 05:50 PM
abadref
Oct 28, 2014 10:16 AM
Melnychuker
Aug 27, 2012 12:02 PM
CAD Stewie
Aug 14, 2010 04:57 AM
veso_ht
Jul 6, 2006 11:05 AM
