home made shift knob
so i decided to attempt and make my own shift knob. i used some scrap aluminum laying around, melted it down. then i got an empty paint can and cut it open. put some fireclay in with a double shot shot glass as the basic mold and once it was dry i poured the aluminum in.
http://imageshack.us/a/img199/6551/image11481.jpg since i have no lathe, i rigged up my drill press with a dremel as the cutter and drilled and threaded a rod into the mold so i could turn it with the drill press. I used duplicolor graphite wheel paint and vht engine coat clear coat enamel as the paint. then baked the knob in the oven. heres a pic of finished knob. http://imageshack.us/a/img843/8403/img11491.jpg |
Well, I'm thoroughly impressed. Looks nice!
thanks man i broke the tab on the oem one that goes over the shifter and holds the boot upand got tired of having sloppy shifting
