Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
home made shift knob
Old May 27, 2013 | 08:12 AM
tofast2belast's Avatar
Default home made shift ****
so i decided to attempt and make my own shift ****. i used some scrap aluminum laying around, melted it down. then i got an empty paint can and cut it open. put some fireclay in with a double shot shot glass as the basic mold and once it was dry i poured the aluminum in.
since i have no lathe, i rigged up my drill press with a dremel as the cutter and drilled and threaded a rod into the mold so i could turn it with the drill press.
I used duplicolor graphite wheel paint and vht engine coat clear coat enamel as the paint. then baked the **** in the oven.
heres a pic of finished ****.
Old May 27, 2013 | 05:37 PM
audiaxel's Avatar
Well, I'm thoroughly impressed. Looks nice!
Old May 30, 2013 | 07:48 AM
thanks man i broke the tab on the oem one that goes over the shifter and holds the boot upand got tired of having sloppy shifting
TEHxFALLEN v1.2
Dec 18, 2010 04:48 AM
bradtyler02
Jul 20, 2010 10:18 AM
greene08
B7 Models
Oct 28, 2008 06:43 PM
ARIaudiS4
Dec 3, 2007 10:15 PM
starting...
Feb 7, 2007 04:15 PM
