Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
It keeps steaming up !!!! A4 front window
Old Nov 24, 2010 | 01:59 PM
mrlee's Avatar
Default It keeps steaming up !!!! A4 front window
UK audi
Ok please can I have some help here from any one who knows? I have a b6 A4 soft top, Now the winter has set in ,im finding my front window steams up and does not dissipate, Now, I know it’s a case of turn on the aircon and this will take the moisture from the air and clear the windows, this is the case for every window except the front, I’ve tried every combination on the split aircon panel . Any ideas .
Old Dec 16, 2010 | 02:15 PM
smthkathleen's Avatar
Default Wind shield coating
IN winter there is some windshield coating liquid, once you apply it can with stand for 6 months it will not allow any mist or fog in the screen, just get in in your location available,http://askdoctorwindshield.com/windshield_coatings.php
so that you dont have to get trouble from youe windshield while driing during the winter season, are try for some window heating element, which is being used in Aeroplanes.
Old Dec 17, 2010 | 06:29 AM
mrlee's Avatar
Thanks ill have a look at it and see what its like
Old Jan 9, 2011 | 10:13 AM
dublinoh's Avatar
Is it possible you have a fan issue...do you feel strong air flow at the windshield.
Also possible you have a small leak in your heater core introducing water to the cabin. Good Luck
Old Jan 9, 2011 | 10:15 AM
dublinoh's Avatar
Originally Posted by lmno055
Bo Ru and wow gold Yang set his legs felt limp, the cheap wow gold complete embody trembling full lace wig violently, upset, and wow gold exclusive a knockout faculty to bond to low wow accounts the barely reticent their hearts with imp.
WTF? was too short so again WTF?
Old Feb 13, 2011 | 10:48 AM
DANGER6's Avatar
I was told at the dealership when I bought my car that when that happens you use the "econ" button and it pulls all the moisture out of the cab.
Sorry if you knew that already, I don't mean to insult you.
Old Mar 24, 2011 | 10:57 AM
krazzz's Avatar
You could also have a small leak in your heater core causing your windshield to steam. Keep a close eye on your coolant level.
Old Apr 21, 2011 | 10:34 PM
niagara24's Avatar
May not apply but I had a problem with trapped water in the battery tray sloshing into the cabin air intake. Found rubber drain spigot in battery tray was plugged with debris. (2005 allroad 2.7t)
savantv
Feb 1, 2012 10:32 AM
jraward
Jan 10, 2012 09:58 AM
mrlee
Dec 5, 2010 09:46 PM
mrlee
Nov 24, 2010 02:00 PM
PinckneyA8
Feb 3, 2008 08:08 PM
