Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Q7 3rd row seat removed
Old May 14, 2013 | 02:30 PM
serac's Avatar
Default Q7 3rd row seat removed
I took out the 3rd row seat in our Q7 to lighten it and save Gas as we don't currently use the 3rd row. Pretty easy to take out, But I am a bit concerned that without the 3rd row the vehicle might not survive a serious accident as well. It is basically a ~2" square steel tube bolted to both rear wheel wells. Taking that into consideration I would recommend this to others as a mod.
slid a flat pry bar under the front of the seat and then pushed down on the bar to pop out the two front attachment points. They are just the metal rod tabs stuck into plastic slots. Unlatched the 3rd row shoulder seatbelt lower attachment points (as they were attached to the seat base). Then removed the four bolts holding the square steel tube bolted to both rear wheel wells. Lifted out the seat. I put the two rear bolts back in after coating them with never seize because the holes go all the way through to the exterior of the car.
Also removed most of the trim in the rear just to lighten it up. Have had it out now since ~2012-08. Makes a little more room in the rear but there is no longer a flat area to lay things on.
Old Feb 10, 2016 | 01:19 PM
fonbetrand's Avatar
Default 3rd Row Seat Installation
My 2007 Q7 doesn't come with a 3rd row seat, but it has space for installation, Has anyone done it before. Any ideas?
I will love to have the 3rd row seat.
Thanks
Auditroubles83
Mar 21, 2015 10:33 AM
srlito
May 2, 2010 01:26 AM
Brycen23
Jul 31, 2007 10:03 PM
varghesea
Apr 9, 2007 04:17 PM
