Dayton or Cincinnati area... Can anyone help me with a trans fluid change?
I have a B7 A4 2.0t with Tiptronic with 86,000 miles. and I have started to notice a rough shift and a little idle bounce when beginning to drive this only happens when cold starting. This goes away after warm up. No codes as of yet. I do not have a Vag-Com.
I figure its best to change the fluid first and see the outcome on this.
Any ideas are appreciated.
Hi
By tiptronic I suspect you mean Multitronic?
I've just had my A6 done. Oil should be changed every 40K miles. Its not a DIY job though. The oil is gravity fed into the gearbox under the car and takes a while to get approx 6 litres into it.
I'd certainly get it done though - it does make a difference to the gear changes.
