Dayton-Cincinnati Area help?
Old May 5, 2011 | 03:47 PM
deansweet's Avatar
Default Dayton-Cincinnati Area help?
Hopefully this is in the correct section.
Anybody located around the Dayton-Cincinnati area that would be willing to help me troubleshoot my 1997 Audi A4 I just purchased and then died?
I am down to it being something with the Immobilizer? It starts, runs a few seconds, then dies. I checked the codes and the only thing coming up is the torque converter code but it had this when it was running as well. How do I know if this car is equipped with the immobilizer? I only have the one key that came with it. I plan on ordering a replacement from Audi here in the next couple days.
Thanks
Dean
So far I have replaced the MAF, Coils, plugs, ICM, fuel filter, fuel relay and pump.
Old Jun 24, 2011 | 09:53 AM
wookieneck's Avatar
sounds like the immobilizer but you should see a code.
you using the Vag-com software? When I locked out my jetta it showed up in there. I let it sit overnight and then tried the known good key and it worked fine.
Old Jul 26, 2011 | 12:57 PM
myaudi98's Avatar
Usually you can take out battery for half hour, plug in and it will run fine for a while, longer than it normally would. See if that works. Had a buddies a6 do the same. Then we removed batter, reinstalled and it worked for like a day normally and then went back to it.
01b5s4
Dec 1, 2009 10:56 AM
spools
Jun 20, 2008 01:20 PM
keepupp
Feb 20, 2008 08:02 PM
Dolomite_TT
Jun 30, 2007 08:26 AM
