Audi A4 1.8t Boost problems!!!
Old Oct 1, 2012 | 06:43 AM
EpicA4mike's Avatar
Default Audi A4 1.8t Boost problems!!!
hi everyone, i am stuck with an ongoing problem i have read loads of people have had simular problems. i have an audi A4 1996 turbo, its been re-maped and lowered, it has a brand new K03 turbo on it and its running manual boost. it works fine if i drive flat out from first gear. but if i try and drive normal and accelerate in gears it splutters and boost will hit its max at about 15psi hold it then make a pop noise drop down for about 2mins to 7'8psi then go back up, but only seems to do it in 2nd 3rd 4th and 5th gears not first. i took out the n75 but left it plugged in and it works every now and then. yesterday i tried to put it back in i heard a pop and now i think in as its called "limp mode"...... please can someone help me, i want it to run about 12psi max and hold it nicely with no problems and no spiking and splutters....
mike
Old Oct 1, 2012 | 01:27 PM
EpicA4mike's Avatar
i have a new turbo but it was doing this before the replacment, and i changed manual booster and it was ok after that it kinda just started doing it i can tried boost leaks and cant find anything, im just stuck i can get it out of limp mode by taking out the N75 and then the boost starts to spike and bounce around i wana be able to get it to reach about 14psi like it was before without the dropping back and struggling, its strange that if i drive flat out from 1st gear then it seems to work perfect, but have to drive flat out
EpicA4mike
Oct 2, 2012 05:39 AM
Bootsy187
Jul 25, 2011 05:51 AM
Phil99a4
Mar 19, 2011 08:18 AM
AyFourBee5
Oct 25, 2010 01:35 PM
a4riderz
Sep 11, 2008 12:24 AM
