2001 TT 1.8 Turbo Problem
I have a 2001 TT 1.8 that just hit 100,000 miles. Great car! Here's the problem. In 4th and 5th gear around 3500 RPM or when I put my foot into it, the turbo doesn't spoil. Instead it feels [jerky,sputters, hesitant]
. Unlike 1st-2nd-3rd, where the turbo throws you back, 4th and 5th do nothing. I found that when its a little cooler outside the car doesn't do the sputter thing [could be coincidental], but still the turbo doesn't kick in. I've heard all types of things from changing the MAF, the DV, the FPR. However I haven't got a straight answer from anyone.
This is what I have done so far:
-new K&N air filter
-new NGK spark plugs
-new Ignition coils
-oil and filter change
-disconnected the MAF sensor to see if that was the problem [no result]
any suggestions would be greatly appreciated. Thanks!!
-Cody
. Unlike 1st-2nd-3rd, where the turbo throws you back, 4th and 5th do nothing. I found that when its a little cooler outside the car doesn't do the sputter thing [could be coincidental], but still the turbo doesn't kick in. I've heard all types of things from changing the MAF, the DV, the FPR. However I haven't got a straight answer from anyone.This is what I have done so far:
-new K&N air filter
-new Ignition coils
-Cody
weird problem, it seems that load is causing the issues. Run your codes, and see what they say. If i had to point at something right now without more info i think the maf is your problem. 01 tts rely on the maf for a lot, so any problem there can cause a bunch of other issues.
I've had the same problem that I posted 2 years ago after I put a diode, boost controller, and greddy air filter in. I still haven't fixed the problem, but mine happens anytime I slam on the gas in any gear. I've tried raising the boost and lowering the boost. Once it spikes and maxes out (the boost controller) it starts sputtering and stops spooling. It's annoying.
It happened before and after I changed spark plugs. One was stock and the other were self gapped... I have to change them again when it warms up... but there has to be another reason this is happening. I really want to videotape this problem and upload it. I will do it soon enough... once it gets warm again
That might not fix it, but its a good idea to replace it anyway at 100k....Do you have a boost gauge installed so you can see what's going on or are you just going off of how the car feels? I don't trust pre-gapped spark plugs. What are you gapped at? Are you chipped?
Problem Resolved!!
OK, I finally broke down and really go into the turbo. After many hours I found a ton of collapsed and torn vacuum hoses. The big thing though was the waste gate actuator was bad. Now everything works great. Now the only thing I need to do is adjust the waste gate for a bigger boost. Does anyone know the correct way to do this?
