Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
All of you with Nitrous....
Old Apr 13, 2007 | 04:31 AM
java's Avatar
Default All of you with Nitrous....
post up pics/specs of your setups! just trying to get some more info, searching just pulls up alot of nitrous bashing, so plase keep it to a minimum.... i heard a rumor that a couple peole had direct injected set ups is this true?
Old Apr 13, 2007 | 11:39 AM
Bondga's Avatar
Default RE: All of you with Nitrous....
skip the nitrous and invest in some real power....
Just my 2¢
Old Apr 13, 2007 | 11:49 AM
Hey_You's Avatar
I'm guessing that you are a 2.8...and probably a 12v too. In which case, Nitrous is your only friend. I would say get a book on the stuff...READ IT...and then do your own install. Just don't be stupid and put a 150 shot in a car that only makes 170hp (still assuming you are 12v)
Old Apr 13, 2007 | 03:08 PM
java's Avatar
ok well i have quite a bit of knowledge of nitrous and cant afford a Sc for a few more years, so i thought i would take a look at what other audi peole have put together and see what i think aobut it. i have seen the B6 on Aw that has it and ive seen one other guy on here that has a pic in his sig, there are alos some rumors of someone haveing a direct injected setup, on this board. if i were to do this set up most likely i would be runnign 50 shot jets at most, and no i have a 30V.
Old Apr 13, 2007 | 06:03 PM
cincyTT's Avatar
I'm make believe
1.8t's can do a 50-75 wet shot of nitrous safely. A 30v should be able to handle a 75-100 wet shot easy if not more with a direct port setup. You will need to upgrade the fuel pump also. I wouldnt recommend anymore than that cause you will need to lower your timing with more and make sure your using 91octane or higher.
Old Apr 13, 2007 | 10:45 PM
java's Avatar
thats the one question i have. does anyone know what the stock fuel pressure is? i have a gauge nut havent gotten around to putting it in yet...
Old Apr 14, 2007 | 01:28 AM
kakarot's Avatar
i would think about 35psi.
Though I do not like Nitrous, it can provide instentenious power when needed.
The SC or Turbo would be better as it will provide more continious power.
Old Apr 14, 2007 | 06:32 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: kakarot
3bar or ~44psi
Old Apr 14, 2007 | 11:10 PM
java's Avatar
awsome thanks!
Old Apr 18, 2007 | 04:26 AM
java's Avatar
isnt 3 bar 44 psi?
