I'm make believe
twin chamber vs diaphram
the hks is way more advaced than a greddy that just pulls the diaphram up to release the air.
Please read up and look over the diagram before making comments filled with no knowledge again.
http://store.racinglab.com/mit3019turhk.html
i know how it works. it has three valves to release the pressure. unlike most bov were they use the pressure to release the ssqv is hooked to the gas pedal so that every time you let off the gass it will release pressure. this eliviates the problem of spring activated ones, were they either dont let out enough pressure or they dont blow off under low pressure.
but just becasue it works diff dosnt mean its good for a closed loop system it still vents to the atmosphere
I'm make believe
its hooked up to the gas pedal. Thats funny, please tell me that was a joke! It still runs on vacumm, once again please start reading before you keep posting in this thread. Thanks
I'm make believe
Quote:
ORIGINAL: Bondga
but now after reading i dont know what the hell that wire was
Its called a vacuum hose. Man i hope you dont work on your or anyone elses car.ORIGINAL: Bondga
