Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
can turbocharge 1.8 A4?
Old Apr 14, 2006 | 09:49 AM
reaseaaudi's Avatar
Default can turbocharge 1.8 A4?
can 1.8 engine install turbocharge?
Old Apr 14, 2006 | 10:47 PM
kakarot's Avatar
Default RE: can turbocharge 1.8 A4?
yes, low psi, no higher that 30% gain, Why?
Old Apr 15, 2006 | 02:55 AM
reaseaaudi's Avatar
actually i would like to upgrade the car to turbocharge but pending on whether to install 1.8T engine or just the turbo kit.
so any suggestion?
Old Apr 15, 2006 | 02:55 PM
kakarot's Avatar
how much power do you want?
you understand that you are limited on boost becouse of the compresion ratio.
maximum you could probably get is 170HP @ 8psi.
and probably 180-185HP @ 8psi with IC.
you could probably do a cheap build up. for less that 1000 buks to turbo charge.
what you could have is lagless engine.
more info?????
Old Apr 16, 2006 | 04:41 PM
kakarot's Avatar
PS its cheap
ahh, check out www.mazda626.net there is a how to and there find "how to make your car sneaze" cheack out the links on www.mx6.com
the principles are the same for all cars.
Old Apr 18, 2006 | 11:05 AM
reaseaaudi's Avatar
tks mate.....i ll check on the links.....good to talk to you
Old Apr 18, 2006 | 11:09 AM
kakarot's Avatar
welcome
Old Apr 19, 2006 | 05:08 PM
ChiTowNS401's Avatar
wtf?? What language was that in?
Old Apr 19, 2006 | 08:16 PM
kakarot's Avatar
which one, quate please )
here I make links
forum: http://www.mazda626.net/index.php?showtopic=264
guide: http://www.mx6.com/forums/showthread...3&page=1&pp=15
its easy, If I had I4 and a welder I could do it.
Old Apr 22, 2006 | 04:58 AM
reaseaaudi's Avatar
just wondering if i install a 1.8T engine, should i change the radiator support? what else should i change?
