Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
how much boost
Old Nov 20, 2007 | 10:44 PM
driftking8732's Avatar
Default how much boost
i have an audi a4 1.8t b5, i just purchased a gt2871r, 4 bar(fpr), 415 injectors, new fuel pump, and im looking into software. what kind of boost can i run on my car, without doing internal, i will do that stuff later after i finishing paying this off, im just looking for what kind of boost i can push undr these conditions.
Old Nov 25, 2007 | 05:48 PM
cincyTT's Avatar
I'm make believe
Default RE: how much boost
If you have a AEB engine, 23-24 should be fine, if you have a ATW, 22psi would be about the max. Also you should have a good boost controller of some sort. One good boost spike and you could have a hole in the block with ease.
Old Nov 26, 2007 | 04:26 PM
thanks and it is an awt, and i have picked up an aem true boost for the boost controller, since it seems you know a lot, someone told me that the weekest link in the a4 is the connecting rods, they also said about 330bhp is about all it can handle internal wise, is this true? also if it is true what internals should i start with to be able to increase the boost?
Old Nov 26, 2007 | 06:39 PM
cincyTT's Avatar
I'm make believe
The tq is what breaks rods. I have seen as much as 380whp (driven daily) to 500whp (just a dyno) on stock rods. It all depends on the turbo and a/r of the turbine. The ATW uses 19mm wrist pins and you can just get some intergrated engineering rods (~$320). That will let you run the turbo at its full potention and max it out with w/m and/or race gas.
Old Dec 9, 2007 | 01:03 PM
get audi here's Avatar
I agree torque breaks parts.
What is max torque for stock rods?
Old Dec 10, 2007 | 01:20 PM
cincyTT's Avatar
I'm make believe
depends on the turbo used. But on 19mm* rods, 300-310 is about all i would push. For 20mm* rods, 320-330 is pushing it. *wrist pins
TeeterTawter
Jan 20, 2013 12:14 PM
to4xxx
Jun 8, 2012 11:56 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
eliTTe
Oct 11, 2007 04:12 PM
onepoint8tee
Jun 27, 2007 04:38 PM
