Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
How will K04 effect my car's tune??
Old Jul 11, 2012 | 12:58 PM
Wangwazu's Avatar
Default How will K04 effect my car's tune??
I own a 2003 1.8t a4 and since owning these have been the modifications...Stage 1 software, k&n hp air filter, 3 inch turbo back exhaust (catless). Recently the bearings in my stock turbo went, so i went and picked up a k04. My question is how will this effect the tune i already have for the set up previous to this new turbo? Will I need to tune again if I don't upgrade my fuel injectors?
I eventuallu want to do a fmic and the bigger injectors but am not in a rush to untill my funds are in order. Also any suggestions for fuel injectors for this set up?
Thanks
Old Jul 11, 2012 | 01:58 PM
MetalMan's Avatar
Generally speaking a K04 can be used as a direct drop-in replacement for a K03. Running the same tuning, power gains won't be much, but should be a little more noticeable in higher RPMs where the K03 "runs out of breath".
You'll definitely notice gains when you jump to a K04-specific tune with higher-flowing injectors, which will require an upgraded intercooler. Note that typically you should only change injectors when you change to a tune which requires them (i.e. if you have a Unitronics 440cc tune, then you'll run 440cc injectors).
Arnold's Audi
Mar 8, 2015 09:26 PM
audinovice0819
May 20, 2009 07:07 PM
joshd2012
Nov 20, 2007 03:47 AM
mrvuml
Oct 6, 2007 01:00 PM
audilover04
Jul 30, 2005 02:05 PM
