Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
More boost
Old Oct 12, 2011 | 10:16 PM
ckrummy's Avatar
Default More boost
I have a 98 A4 1.8t, i already have a GIAC chip, i'm told that a ko3 maxes out at 22-25psi of boost but how do i safely max out my turbo? i know rods are a good idea for over 250 hp
Old Oct 12, 2011 | 10:58 PM
02quattrokev's Avatar
Safley maxing out the turbo would be to not max it out lol. Running that little turbo at 22-25 psi would no doubt work, but for how long ? I've seen the k03 with 20 psi and no internals blow the turbo in 6 months, no engine damage. My 02 A4 1.8T has the AMB engine and i'm pretty sure that it has forged bottom end, no need to do it unless your upgrading to a bigger turbo.
Old Oct 12, 2011 | 11:18 PM
ckrummy's Avatar
Thanks, keeps me from making a mistake, i'll just have to save up some $$$ if i want more power
Old Oct 13, 2011 | 10:37 PM
I'm in the same boat, i don't know your engine code but mine is the AMB engine 1.8T 180HP. My plans is stage 1 which includes, APR ECU flash which i'm looking to run mabey 15-17 lbs of boost on the stock ko3 sport ( 499.99 ) Aftermarket intake box w/ turbo inlet pipe ( 500.00 ) and a tubo back exhaust not sure which one yet so but those are about 1200 for a nice one. I plan to buy all these together for a nice quick ride that will sound good and hear the turbo nice. That should be your start as well. You could even add injectors at a later time and should help out a little more, and set you up for a ko4 later! This is my idea, hope this helps.
Old Oct 14, 2011 | 12:54 PM
ckrummy's Avatar
Yeah i think injectors would help but if your going to do them you should get them before you install the chip, so they can adjust for them.
Old Oct 14, 2011 | 05:23 PM
turbo kraut's Avatar
Tech Guru
that is not what he should do, if he is going to do injectors.... he needs to go 1+
and 25 psi is maxing or coming damn close to making a k03
Old Oct 15, 2011 | 06:03 AM
ckrummy's Avatar
sorry that's what I ment, the car needs to be tunned for the injectors that are in it.
TeeterTawter
Jan 20, 2013 12:14 PM
to4xxx
Jun 8, 2012 11:56 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
eliTTe
Oct 11, 2007 04:12 PM
onepoint8tee
Jun 27, 2007 04:38 PM
