Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
oil system for turbo
Old May 25, 2006 | 03:50 AM
greekA4's Avatar
Default oil system for turbo
hey everyone. Ive looked around in many forums on this site and have not come upon anyone mentioning how the lubrication system works or is set up for a turbocharged A4. I would love to know where you would tap for oil, and how would you feed it to the turbo. Also, any specific hardware (oil feed lines, connectors, pumps, etc.) that you would recommend getting for an upgraded custom turbo kit.
Old May 26, 2006 | 03:23 PM
greekA4's Avatar
Default RE: oil system for turbo
anyone??????? im sure theres some of you out there that now this, SO JUST ANSWER!!... kakarot, you prolly know this....
Old May 27, 2006 | 12:37 AM
kakarot's Avatar
I know, maybe not lots but I know.
the stock A4 that came with turbo stock, is quite very easy system.
i THINk that the oil pump is much stronger that NA engine of the same displacment.
or you mean if you turbo a NA engine to where you need to plug in?
sorry, I did not answer sooner, someone broke my drivers front window. BLOODY BUSTARDS on who did it !!!!
Old May 28, 2006 | 12:56 PM
greekA4's Avatar
thank you for answering kakarot. Yea i kinda meant if i use an aftermarket turbo with an na engine, where do i plug in the oil feed? i know one end goes to the center of the turbo, but where does the other end go?
Old May 28, 2006 | 02:01 PM
kakarot's Avatar
oh the exit. goes directly to the oil pan, above the oil level. Important ABOVE.
the feed in goes from a T splicer where the oil presure sensor is.
read a book 0-89586-135-6 it explains all.
Old May 29, 2006 | 02:54 PM
greekA4's Avatar
Thank you Kakarot.
Old May 29, 2006 | 03:00 PM
kakarot's Avatar
Welcome, always glad to help.
anything else?
Old May 29, 2006 | 03:52 PM
greekA4's Avatar
sorry.. i just wanna make sure i understood correctly.. so i need to drill a new whole above the oil level in the oil pan, and stick in a t splicer where the oil pressure sensor is?
Old May 29, 2006 | 05:56 PM
kakarot's Avatar
ye
above the oil level. but you have to make sure that you make no leak. thats mean dril & tap or better, remove the carter and dril and use the sandwitch type conector to make use that it wont leak.
Old May 30, 2006 | 02:31 AM
greekA4's Avatar
what about the oil feed to the charger on a 2.8L 30valve? should that run off or tap or go by, or something like that, by the oil pressure sensor? if so, where is the oil pressure sensor?
