Stock Psi
Stock Psi
I tried searching but it wouldn't work.
Question is.. I just installed the awe boost gauge and im not shure what psi i should be at. The car is completly stock and im holding 10psi untill 5000rpm then its going down to around 8 is this normal?
RE: Stock Psi
Volkswagen Engine Info
Engine Code: AWD
Model Years: 2000 (11/99 on)
Compression Ratio: 9.5:1
Horsepower (SAE Net): 150hp @ 5700RPM
Torque: 155ft. lbs.@ 1750RPM
ECU: Motronic ME7.5
DP Size: 55mm (2.17")
Turbo: K03
OE Boost: .6 Bar (8.7psi)
Engine Code: APH/AWV
Model Years: 2000/2001
Horsepower (SAE Net): 150hp @ 5500RPM
Torque: 155ft. lbs.@ 1950RPM
ECU: Motronic ME7.5
DP Size: 50mm (1.97")
Turbo: K03
Engine Code: AWW
Model Years: 2001 (07/00 on)
Compression Ratio: 9.3:1
Torque: 162ft. lbs.@ 1950RPM
ECU: Motronic ME 7.5
Turbo: K03s
Engine Code: AWP
Model Years: 2002+ (06/01 on)
Horsepower (SAE Net): 180hp @ 5500RPM
Torque: 174ft. lbs.@ 1950RPM
ECU: Motronic ME7.5
Turbo: K03s
OE Boost: .8 Bar (11.6psi)
Audi Engine Info
Engine Code: AEB,ATW,AUG
Model Years: 1997-2000
Horsepower (SAE Net): 150 @ 5700 RPM
Torque: 155 ft. lbs.@ 1750 RPM
ECU: Motronic ME7.1
Turbo: K03
Engine Code: AWM
Model Years: 2001-2005
Horsepower (SAE Net): 170 @ 5900 RPM
Torque: 166 ft. lbs. @ 1950 RPM
ECU: Motronic ME7.1
Turbo: K03s
Engine Code: AWD
ECU: Motronic ME7.5
Turbo: K03
ECU: Motronic ME7.5
Turbo: K03
Engine Code: AWW
Turbo: K03s
Engine Code: AWP
ECU: Motronic ME7.5
Turbo: K03s
Audi Engine Info
ECU: Motronic ME7.1
Turbo: K03
Engine Code: AWM
ECU: Motronic ME7.1
Turbo: K03s
dc878mmm
11-02-2013 02:02 PM
luxuryimports1
10-07-2009 04:40 PM
Ringin'It
02-03-2009 02:38 PM
A4 the Quattro
11-10-2007 10:20 PM
ZIV3R
09-20-2007 01:55 PM
