1982 RollsRoyce ?
Old May 29, 2007 | 09:19 AM
snapaj's Avatar
Default 1982 RollsRoyce ?
It`s a SilverSpirit. If I do not start the engine I can push it around anywhere I what BUT as soon as I start the engine the brakes lock-up I don`t even put my foot on the brake and they`ll lock-up! Any Ideas?
Thanks
snapaj
Old May 29, 2007 | 10:17 AM
myaudi98's Avatar
Default RE: 1982 RollsRoyce ?
Maybe you should try the Rolls Royce forums! lol
jk
Old May 29, 2007 | 10:22 AM
snapaj's Avatar
Did that 2months ago. No replies!
Old May 29, 2007 | 10:26 AM
myaudi98's Avatar
i say check the brake lines! drain, refill, bleed and see if that does the trick.
Old May 29, 2007 | 12:17 PM
snapaj's Avatar
myaudi98 Thank You I`ll try that and post results
snapaj
Old May 29, 2007 | 01:00 PM
AWDaholic's Avatar
Senior Administrator
I'lll bet avant80 knows what the deel-E-o is
Old May 29, 2007 | 01:12 PM
snapaj's Avatar
ya avant80 told me that if I had needed anything els to just ask...
Thanks
Old May 29, 2007 | 02:21 PM
techbod's Avatar
Default RE: 1982 Rolls Royce ?
hmmm very interesting problem I would put it down to a bad break booster drawing excess air and pulling the break peddle in ( has there been any mods to the breaks ) are the vacuum pipes connected to where they should be and is the one way check valve in the in the vacuum line from the break booster ( it might also be the check valve has failed which will cause a similar reaction ) worth a try,
edit: also check if the check valve is facing the right way
Old May 29, 2007 | 07:40 PM
KiloByte's Avatar
ORIGINAL: snapaj
Problem is, I don't think most Rolls owners even know how to change the oil. I'm sure they'll give you some pointers on how much they tip their chaffeur to take it in for them.
Old May 29, 2007 | 07:44 PM
QuattroChucko's Avatar
Or where the closest place to buy grey poupon is
