1982 RollsRoyce ?
It`s a SilverSpirit. If I do not start the engine I can push it around anywhere I what BUT as soon as I start the engine the brakes lock-up I don`t even put my foot on the brake and they`ll lock-up! Any Ideas?
Thanks
snapaj
Thanks
snapaj
hmmm very interesting problem I would put it down to a bad break booster drawing excess air and pulling the break peddle in ( has there been any mods to the breaks ) are the vacuum pipes connected to where they should be and is the one way check valve in the in the vacuum line from the break booster ( it might also be the check valve has failed which will cause a similar reaction ) worth a try,
edit: also check if the check valve is facing the right way
ORIGINAL: snapaj
Did that 2months ago. No replies!
