1988 M5
Old Feb 24, 2006 | 01:36 AM
socalaudi's Avatar
Default 1988 M5
I ran into an old friend last night. He says hes got an 88 Bmw M5 with a custom T4 turbo set up. Hes claiming hes got like 500 hp. I haven't seen it yet but he says it will blow me away when he takes me for a ride. He also works at an independent shop and says he will do my timing belt for like $20-30 an hour. Thats a sweet deal. I dunno to much about turbos so dont hold me responsible for what Im saying, Im just repeating what he told me.
Old Feb 24, 2006 | 02:16 AM
BFlan2001's Avatar
Default RE: 1988 M5
it might be fast, but i doubt he's pushing 500hp
Old Feb 24, 2006 | 05:26 AM
Karl's Avatar
Default RE: 1988 M5
this is a 1988 M5, if he says he is putting out 500hp, ask for the dyno.. because I am going to call "Shenanigans" on that
Old Feb 24, 2006 | 05:36 AM
BadLuckAudi's Avatar
Default RE: 1988 M5
lol yea i think 500hp is probably a little over estimated, lets see the dyno sheet
Old Feb 24, 2006 | 05:46 AM
SilverSeven's Avatar
Default RE: 1988 M5
Some T4s are capable of pushing out of 50lbs/minute, so I don't doubt that he could have 500hp, but with the stock compression ratio, he would probably need water/meth to safely run the required boost levels. 500hp on a T4 is pushing that turbo pretty hard. It would probably take 27-30psi to make it that high.
Old Feb 24, 2006 | 03:03 PM
socalaudi's Avatar
Default RE: 1988 M5
Yeah he was just guessing. He told me he was only at 20psi so yeah its probably not at 500. Also he was talking crank not whp.
Old Feb 24, 2006 | 03:15 PM
99a4audi's Avatar
Default RE: 1988 M5
sounds fast, but i dout 500hp
Old Feb 24, 2006 | 03:19 PM
Default RE: 1988 M5
ORIGINAL: socalaudi
Oh, well crank ratings could pretty easily be 500 at 20psi. Remember, that's only around 400 wheel hp. Good numbers, but not really that hard to make if you know what you're doing. Keep in mind that the 88 M5 was rated stock at 250ish, and every 14.7 pounds of boost that you add is effectively doubling the displacement.
Sounds about right then.
Old Feb 24, 2006 | 05:44 PM
tealetm's Avatar
Default RE: 1988 M5
ORIGINAL: Redgoat
"I swear to God I'm going to pistol whip the next guy sho says Shenanigans. Her Farva, what's the name of that restaurant you like with all the goofy stuff on the walls and the mozzarella sticks? You mean Shenanigans???"
Old Feb 25, 2006 | 01:07 AM
socalaudi's Avatar
Default RE: 1988 M5
I just talked to my bro and he said his car has a motor out of euro m6 which gives him 286 stock. He also has a chip and full ehaust. He just got a new fuel pump for it and is installing it tomorrow. After that hes going to take me for a ride. I can't wait. He also said it smokes 1,2, & 3 no problem so Ill keep you guys updated.
