Answer a question & Ask any question?
A. Stop by the indy shop. Check engine light came on. Hoping it is the fuel fume sensor thingy error/failure that happened before. 1 out of 300 some odd tests failed.
Q. What are you gonna do now that I'm going home?
A: it means....."don't call us, we'll call you!" hmmmmm, good question. i guess i'd say, sometime between now and then.
Q: will you ignore said call/text when it comes and return it in a "little bit"?
A: yes. always go to class. especially the last day. that's when the prof gives you the inside scoop about the final.
Q: have you found any good glass cleaning product that doesn't streak? i have the hardest time cleaning my cars interior windows. it looks fine and dandy when i'm done, but the minute i drive it in the sun, i see all the wipe marks.
A. I use this foam based glass cleaner that I found out about when I was doing some cleaning work, I like it but you can only get it at commercial grade stores
Q. What's the best way to get spray paint off of wood floors?
A: ooo that's not good. spray paint is pretty permanent. just about anything you use will take the varnish coat off and possibly change the wood stain color. if it's a small area, i'd try the mr clean magic eraser...although i did that on my floor once and it did kinda take the shine off. maybe some paint thinner or fingernail polish remover, if you use it on a q-tip or something to control it. all those things will take the varnish off too.
Q: don't you know, you're supposed to spray paint OUTSIDE?
