AudiForums.com
-   Off Topic (https://www.audiforums.com/forum/off-topic-5/)
-   -   Cold Heat (https://www.audiforums.com/forum/off-topic-5/cold-heat-139386/)
louisem381 Sep 25, 2009 03:38 PM
Cold Heat
my new/used audi a6 manual does not explain how to get the heat to come on. The Auto feature seems to work but never gets warm, and i don't know if it's my settings or it is not working. Nights are getting chilly here.
kriptonik Sep 25, 2009 03:49 PM
Adjust the temperature all the way up. It should say something like HI on the display.
Also you need to wait until the engine gets warmer for the heat to kick in.
AWDaholic Sep 25, 2009 04:06 PM
Sit in your hunnies lap, you work the gas, they work clutch, that outta heat things up.:p:);) You get bored, SWITCH; they sit in your lap, you work clucth, they work gas! :eek::rolleyes::cool: Whoever's on TOP steers:D.
louisem381 Sep 25, 2009 06:15 PM
Cold heat
Thank you--I did see that was not sure if it would work. :o
AWDaholic Sep 25, 2009 11:22 PM
You're talkin bout MY solution, RIIIIIIIIIGHT?!?!?!
airguard350 Sep 26, 2009 01:51 AM
^ Oddly enough Jazz, your solution was in my owners' manual.
yesss4 Sep 26, 2009 02:07 AM
The temp controls in Audis are goofy. It's 50 outside and you want heat so you put the temp to 70, but it blows cold. Like said earlier, crank the thing all the way up if you want heat.
airguard350 Sep 26, 2009 09:56 AM
I usually find that setting it to 75 gives me heat.
AWDaholic Sep 26, 2009 02:57 PM
Same here... It's where I got it from, 'cept is looked like THIS:
Sitzen Sie im Schoß ihres Honigs, Sie arbeiten das Gas, arbeiten Sie sie Kupplung. Das sollte Dinge erhitzen. Wenn Sie gebohrt werden, Schalter; sie sitzen in Ihrem Schoß, Sie arbeiten Kupplung, arbeiten sie Gas! Wer ist auf OBERSTEN dreht das Lenkrad.
I can't show the pictures! :eek: TOO GRAPHIC!!!
achTTung Sep 27, 2009 07:51 PM
Then certainly don't look at the pics in the first aid kit. Ever read that fold out pamphlet? More or less says at one point, if you don't think the injured person is gonna make it, just be quiet and let them die with dignity. geez....
