Cold Heat
Old Sep 25, 2009 | 03:38 PM
louisem381's Avatar
Unhappy Cold Heat
my new/used audi a6 manual does not explain how to get the heat to come on. The Auto feature seems to work but never gets warm, and i don't know if it's my settings or it is not working. Nights are getting chilly here.
Old Sep 25, 2009 | 03:49 PM
kriptonik's Avatar
Adjust the temperature all the way up. It should say something like HI on the display.
Also you need to wait until the engine gets warmer for the heat to kick in.
Old Sep 25, 2009 | 04:06 PM
AWDaholic's Avatar
Senior Administrator
Sit in your hunnies lap, you work the gas, they work clutch, that outta heat things up. You get bored, SWITCH; they sit in your lap, you work clucth, they work gas! Whoever's on TOP steers.
Old Sep 25, 2009 | 06:15 PM
louisem381's Avatar
Default Cold heat
Thank you--I did see that was not sure if it would work.
Old Sep 25, 2009 | 11:22 PM
AWDaholic's Avatar
You're talkin bout MY solution, RIIIIIIIIIGHT?!?!?!
Old Sep 26, 2009 | 01:51 AM
airguard350's Avatar
Tech Guru
^ Oddly enough Jazz, your solution was in my owners' manual.
Old Sep 26, 2009 | 02:07 AM
yesss4's Avatar
The temp controls in Audis are goofy. It's 50 outside and you want heat so you put the temp to 70, but it blows cold. Like said earlier, crank the thing all the way up if you want heat.
Old Sep 26, 2009 | 09:56 AM
Tech Guru
I usually find that setting it to 75 gives me heat.
Old Sep 26, 2009 | 02:57 PM
AWDaholic's Avatar
Same here... It's where I got it from, 'cept is looked like THIS:
Sitzen Sie im Schoß ihres Honigs, Sie arbeiten das Gas, arbeiten Sie sie Kupplung. Das sollte Dinge erhitzen. Wenn Sie gebohrt werden, Schalter; sie sitzen in Ihrem Schoß, Sie arbeiten Kupplung, arbeiten sie Gas! Wer ist auf OBERSTEN dreht das Lenkrad.
I can't show the pictures! TOO GRAPHIC!!!
Old Sep 27, 2009 | 07:51 PM
achTTung's Avatar
Then certainly don't look at the pics in the first aid kit. Ever read that fold out pamphlet? More or less says at one point, if you don't think the injured person is gonna make it, just be quiet and let them die with dignity. geez....
