The definition of monotony.
Old Jun 1, 2008 | 03:06 PM
achTTung's Avatar
Default The definition of monotony.
I'll get a pic up in a couple minutes once I get the shop cleaned up a little bit, but I'm wrapping up some welding on some steel railings.
26 railings
approx 21 stiles per railing (stiles are the vertical pieces)
1 decorative bar welded to the top of each railing, about 14 welds.
If you want to count the welds holding the stiles in place at each end as 1 weld, it's approx. 1,400 welds.
If you count each side of the square stiles as it's own weld, which is how I put them together (weld one side, other side, then top, flip railing, and weld top again), that totals about 4,700 welds if my math is right.
4,700 welds = half of my KW Variant 3's that on their way... : )
Old Jun 1, 2008 | 03:26 PM
achTTung's Avatar
Default RE: The definition of monotony.
That's most of them, I have another small pile that may need a little finishing, depending on what the boss says.
Old Jun 1, 2008 | 03:28 PM
CAB509's Avatar
6th Gear
wow, I'm sure that was fun.
Old Jun 1, 2008 | 03:48 PM
achTTung's Avatar
I don't mind it until my face starts to itch a lot from all the heavy metal fumes depositing on my skin, and mixing with the sweat. Then it's time to take a break to cool/rinse off, and then it's back to it.
Old Jun 1, 2008 | 04:24 PM
CLX's Avatar
CLX
Zombie Defense Force
I need to learn how to weld! I have a whole mess of tubing that needs to be turned into a roll cage for my Miata!
Old Jun 1, 2008 | 05:03 PM
achTTung's Avatar
I'd say it's easy, but it takes a bit of natural talent.
Sticking an exhaust together, or making some little bracket is one thing, but structural, like a cage or roll bar... you might want to practice up a bit before trying that, or leave it to a professional.
Once you get it though, it gets to be second nature. I used to start to fall asleep when I worked production TIG welding. It was just a fused weld, no filler metal, so all you do is move the torch along the seam. I'd zone out, and when I came to again, I'd be at the end of my weld!
Old Jun 1, 2008 | 05:35 PM
S4sweeteeteeRS's Avatar
i think the 5th bar from the left is uneven.
Old Jun 1, 2008 | 05:42 PM
achTTung's Avatar
ha. funny girl.
I'm a professional, therefore, they're all perfect! ; )
Old Jun 2, 2008 | 03:34 AM
Audi_Skydiver's Avatar
Thats something I want to learn. THere have been many times where i needed to have something welded but had to go take it to a friends house or shop. Grr...
Josh
y^0
Mar 30, 2010 11:37 PM
bleak17
Oct 14, 2007 04:12 PM
Iceman9100
Sep 11, 2006 01:31 PM
