Ford van and serpentine belt slips off!
Old Mar 22, 2008 | 11:02 AM
spectrum's Avatar
Default Ford van and serpentine belt slips off!
I am having a problem where the serpentine belt will slip off after short periods of driving. The belt brand new will come off after say 200 to 300 miles. It first started after I had the engine replaced with a used one. Van motor is a ford 4.9l inline six. What could cause this? Since I have replaced the tensioner pulley, starter and smog pump. I use the van for work and have been burning through belts been under the hood more than enough times. Thanks for any replies
Old Mar 22, 2008 | 12:01 PM
originalspanksta's Avatar
Default RE: Ford van and serpentine belt slips off!
get a straightedge and check the alignment of your pulleys, one is probably off a little, or is bent and wobbling.
Old Mar 22, 2008 | 12:23 PM
spectrum's Avatar
Ok, If off how would I adjust? Washers. I think all pulleys are spinning straight I'll check again
Old Mar 22, 2008 | 10:47 PM
karguy427's Avatar
Assuming all the pullys are in alignment,I think you may not have enough tension on the belt. Tighten it up.
Old Mar 23, 2008 | 12:27 AM
acamillo's Avatar
Do ford's have tensioner pulleys? If so that might fix s***
Old Mar 23, 2008 | 02:26 PM
spectrum's Avatar
ORIGINAL: acamillo
They do I think i'm going to replace again maybe defective.
Old Mar 24, 2008 | 01:33 AM
acamillo's Avatar
wow i guess i should have read a little more closely, oh well, good luck with your belt
Timon
Jul 7, 2012 01:29 AM
asaucedo3
Mar 2, 2009 07:37 PM
mpdillon
Mar 23, 2007 11:01 AM
Redline.
Oct 22, 2006 05:38 PM
dragondesigns
Aug 13, 2006 02:24 AM
