How I fixed my Audi A6 throttle issue with "Throttle Reset OBD2" ELM327
Hi,
Sharing my experience !!
I Fixed my Audi A6 Quattro 2006 throttle Issue with ELM327 "Throttle Reset
OBD2"
I had my car sitting in my garage more than 2 years and I jump started car
and turned on but but car was shaking and turning off, so my friend was a
mechanic and he diagnosed it and told me that it was throttle issue, so I had
an old elm327 v1.5 bluetooth obd2 adapter and after searching I came upon
this application on google play "Throttle Reset OBD2" which claims to do
throttle adaptation and reset but still I managed to take a risk and try it on my
AUDI and I hooked up obd2 adapter and turned ignition on pressed on clear
codes and then reset throttle adaptation and then adaptation process , after
process was done I turned on car and was running so smoothly. I just
wanted to share this application with you guys maybe it might help you save
you from paying soo much in order to fix a small issue.
I followed this article: Need technical support and help with using Throttle Reset OBD2 application ?
and download from Google Play : https://play.google.com/store/apps/d...et&hl=en&gl=US
OBD2"
