Lowering cars...
Old 04-16-2008, 10:00 PM
Carlos10704's Avatar
Default Lowering cars...
Is it ok to just replace my springs instead of spending an extra $900 on coilovers to lower my car?
I'm looking at these..... will they mess up my stock shocks?
Old 04-16-2008, 10:44 PM
sineo's Avatar
Default RE: Springs...
ORIGINAL: Carlos10704
Yep. Sport springs will put a lot of load on your shocks.
Old 04-16-2008, 11:13 PM
what if I pair them with these shocks?
Old 04-16-2008, 11:15 PM
CAB509's Avatar
6th Gear
then you will probably be fine.
Old 04-16-2008, 11:21 PM
nvm... $400 more I get the H&R coilovers.... ugh lowering the car is more expensive then I thought... I mean i can always pay $40 to get my stock springs cut lol
Old 04-16-2008, 11:25 PM
CAB509's Avatar
6th Gear
screw cutting, just get a torch and heat them up. I swear it will not hamper ride quality at all
Old 04-17-2008, 12:26 PM
If I get 19" rims and just slap on 235/45/19 tires on them to fill in the gap in the fender, does the bigger then recommended sidewall screw up the car in any way? The entire Wheel diameter will be 27.33" instead of 25.33"....
Old 04-17-2008, 03:29 PM
Old 04-17-2008, 05:46 PM
CAB509's Avatar
6th Gear
if you are more than like 4% different with your overall radius, you can have negative effects on your car requiring additional work and a recalibration of the speedometer/odometer.
I'll look for the site I was playing with that lets you know if the %difference is acceptable or not.
http://www.1010tires.com/tiresizecalculator.asp
Old 04-17-2008, 07:31 PM
whoa... 7% difference... guess I'll be doing my wheels, brakes, and suspension at the end of summer. Sound system, alarm, tints, and Tail Lights comes first
Quick Reply: Lowering cars...
