NEW! 2.7 tt upgrade...492wHP/510wTq I want it!!!
Old May 8, 2006 | 03:23 PM
SP4NK3R's Avatar
Default NEW! 2.7 tt upgrade...492wHP/510wTq I want it!!!
I found it on Autospeeds website
http://www.autospeedperformance.com/
Check out the dyno read and other info and clips....they're running up to 28lbs/1.9bar!!!!!!
ASP GT25R Turbo Kit
Consisting of the following components:
[2] Garrett Honeywell GT25R Turbochargers
• Compressors Machined for Charge Reference Lines
• Turbine Housings Machined and Tapped
• Turbine Housings Modified to facilitate External
Wastegates and WG cavity plugged and welded to help spool.
• Pre-Assembled with all Lines & Indexed for Easy Installation
[1] ASP Stainless Steel Tubular Exhaust Manifolds (set)
[1] ASP HighFlow Downpipes with 200cpi Metallic Catalytic Converters (set)
[2] TialSport 38mm External Wastegates
[2] Split Wastegate Tubing, Flanges and Hardware
[2] Stainless Braided Teflon Lined Oil Feed Lines with AN Fittings and Washers
[2] Stainless Braided Teflon Lined Charge Reference Lines with Banjo Fittings and Washers
[2] Stainless Braided Teflon Lined Coolant Return Lines with AN Fittings, Banjos and Washers
[1] OEM Modified Coolant Feed Line
[4] Turbo Inlet Tubes, Silicon and Clamps
[2] Turbo Outlet Tubes, Silicon and Clamps
[1] Hose Fitting Package for Wastegates, Charge Reference, Coolant Return Hoses and Clamps.
[2] Head Gaskets
[1] High Strength Head Bolt Kit
[1] ASP CNC 85mm MAF Housing (Runs Hitachi MAF Sensor with no Flow Straightener Needed)
[6] 440cc Fuel Injectors on OEM 4 Bar Fuel Pressure Regulator
[4] Fuel Rail Spacers and Hardware
[1] High Flow 255l/hr Fuel Pump
[6] Bosch Spark Plugs
[1] ASP Phenolic Spacers (set)
[1] Gasket Kit for Manifolds, Downpipes and Phenolic Spacers
[1] Motronic Software Tuning – Standard Offering
• 93 Octane Street Program
• Approx. 28psi [1.9bar] Maximum Boost Request to 24psi [1.65] by Redline
• Approx. 15 Degrees Timing Advance by Redline
• Air/Fuel Ratio (AFR) Set to 11.0:1 at Full Load
• Rev Limiter set to 7,100rpm, Speed Limiter Removed
• Fuel Consumption Gauge Calibrated to read Accurately
• Catalyst Plausibility Disabled to Eliminate Check Engine Light (CEL) for Test Pipes
• Lower Boost and/or Octane Specification Available at no additional Charge
Call for Ordering Information
$12,950 MSRP
[IMG]local://upfiles/7261/FF5C8C54960B415BB06C3784874B9A78.jpg[/IMG]
Old May 8, 2006 | 03:29 PM
pturbo's Avatar
Default RE: NEW! 2.7 tt upgrade...492wHP/510wTq I want it!!!
Holy $hit! I'll bet that set up will make your car a real screamer. You would have a real weekend racer to track after that conversion.
Old May 8, 2006 | 03:51 PM
99a4audi's Avatar
OMG thats insane, thats faster then an RS6
Old May 8, 2006 | 04:01 PM
PandaXpress's Avatar
DO IT, i dont see why you shouldnt
Old May 8, 2006 | 04:27 PM
Karl's Avatar
holy crap.. now that is some power!!! Wonder what it is at the crank?
Old May 8, 2006 | 04:29 PM
fenderstrat1184's Avatar
once again I LOVE THE S4
Old May 8, 2006 | 04:30 PM
SP4NK3R's Avatar
ORIGINAL: Redgoat
It tells you in the video clip with the dyno run...630crank hp and 653crank tq
Old May 8, 2006 | 05:34 PM
sooks's Avatar
I think theyve had that for a little while now..
Old May 8, 2006 | 06:17 PM
VB05's Avatar
holy shat...now just to save up for a B5 s4...and then save up again for the kit!
Old May 8, 2006 | 07:33 PM
AWDaholic's Avatar
Senior Administrator
ORIGINAL: 99a4audi
I wonder what you'd end up with if you applied those same tricks to the TTV8 in an RS6?
