Problem Audi a4 2.5tdi fuel system
Hi guys, I have an Audi a4 avant sport 2.5tdi v6 2003 and it was fine up until it decided not to start after I came back from work in it, I know it's fuel related as it fires up with easy start but cuts straight out, also while cranking there is no fuel movement in the fuel line from injection pump to the fuel filter, there's fuel there but just seems to be bouncing in the pipe with engine vibrating when cranking. Had it on vag com yesterday and there is a little pressure in the injection pump but nowhere near enough to start it, he checked the in tank pump on vag com and he said it was dead, my question is..would the in tank pump not working cause the injection pump to Stop? I'm just really confused as there's no fault codes showing either..Tia
