RS Model Line Audi RS4 and Audi RS6..Pure race-car performance technology applied to the comfortable ride for which Audi is known
RS4 Gearbox noise
Old 10-14-2008, 10:33 AM
trutchy's Avatar
Default RS4 Gearbox noise
I am looking at buying an RS4 finally...its a 2006 model with 60,000 Kms on the clock. Other then the milage the car is like new.
The only thing i though was suspect when driving the car was a whining noise that could be heard when letting the car coast down the road at about 20kph. (not braking or accelerating)
Anyone heard of this before???
Old 10-18-2008, 04:11 PM
sp0da's Avatar
I have an '08 and I haven't noticed anything like this on my car. I'm thinking maybe you are hearing the Quattro system possibly....?
I'm assuming it was in gear when coasting down the road? If so, these cars make all kinds of cool mechanical noises.
Old 11-04-2008, 03:51 PM
Transmission noises such as this are most likely the result of worn diff bearings, a worn pinion bearing, or problems with the pinion/ring gear.
Try coasting in different gears with and without the clutch engaged, and see if the noise changes relative to the clutch being in or out and the gear. Also try to put slight pressure on the shift while in a gear and see if that changes the noise.
It's possbile that the noise isn't coming from the transmission at all and can be a wheel bearing, which can be diagnosed by turning on a curve at speed (safely) if the noise increases then the wheel bearing that is being loaded is bad.
cjfoley1985
05-06-2015 07:41 PM
rahip4567
B8 Models
04-10-2013 12:43 AM
happypostie
02-13-2013 05:21 PM
Bashya4
08-17-2010 09:56 PM
yarkony
09-26-2007 12:37 PM
Quick Reply: RS4 Gearbox noise
