'00 S4 Rear Brakes - Help a Lady in Distress!!
Old Apr 30, 2006 | 08:44 AM
ocsue's Avatar
Default '00 S4 Rear Brakes - Help a Lady in Distress!!
What's the secret to retract the rear caliper? I rotate it and it doesn't retract.
Old Apr 30, 2006 | 11:57 AM
shelby69's Avatar
Default RE: '00 S4 Rear Brakes - Help a Lady in Distress!!
need to rotate and push at the same time. its real easy with the tool, i never tried without, but i imagine you can do it if your careful. good luck
Old Apr 30, 2006 | 12:43 PM
techbod's Avatar
yep push and rotate clockwise "one little cheat is to open the bleed nipple" this reduces the pressure when pushing then you will need to bled that cylinder when complete
Old Apr 30, 2006 | 06:02 PM
TheDonn's Avatar
what is the tool called?
Old May 1, 2006 | 12:55 PM
Subherb_s4's Avatar
It's called a caliper tool. A large c-clamp will work as well. I have a 2000 s4 and I use a large c-clamp.
Old May 1, 2006 | 04:07 PM
2k S4's Avatar
This is what you need...
http://www.harborfreight.com/cpi/cta...emnumber=40732
I just did my rear brakes for the first time, and they were a compleat PITA with out the tool! IT's really hard to push and twist at the same time with out the tool. With the tool it took 30sec per side! With out I pushed & turned for 45min on one dam side!
DragonButter32
Jun 3, 2009 02:48 PM
Suli
Mar 18, 2009 06:38 PM
audis4000
Mar 6, 2009 01:39 PM
whiskeyfox
Feb 10, 2007 08:59 PM
wildkim
Dec 4, 2006 02:48 PM
